محمد قاسم
Dec 13
While driving, I hear a buzzing noise at the bottom of the steering wheel in the driver's seat. Sometimes it's there, sometimes it's not. Has anyone experienced the same issue? How did you solve it?
Do your tires pick up stones and fling them onto the bodywork? Can the driver hear it while driving? I can hear it very clearly. 🤔🤔🤔
After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
Hi, what could be causing the steering wheel to make a buzzing sound when turning?
4Is it normal to frequently hear a low-frequency buzzing sound while driving the Taycan?
5When you hear a clunking sound after turning the steering wheel, what's going on?
6How to solve the issue of play and wobble in the steering wheel after lifting a Wrangler?
7Why does the steering wheel vibrate while driving?
8When you enter the GV80 and the driver's seat adjusts automatically, does the buzzing sound continue for a while after it stops moving? Has anyone else experienced this? Thanks.
9Hey folks, my 2014 Haval H2 makes a buzzing noise when I turn the steering wheel all the way while reversing. What's going on?
10On the day of the Mid-Autumn Festival, the reverse camera and 360 stopped working. I went to the 4S shop the next day for recalibration to fix it. Because the steering wheel was vibrating while driving on the highway, I did a wheel balancing and four-wheel alignment. Today, while driving on the highway, I noticed that the speed range at which the steering wheel vibrates has expanded, and now the seat also vibrates above 124 km/h. Can any expert provide some guidance?
