Hi fellow car enthusiasts, does the plastic cover on your engine leak oil? Mine's just over two years old and it's leaking a bit, even dripping down. Should I get it fixed?
Is there a solution for the Kia Sportage valve cover oil leak? Is it a common issue? I bought a 10-year-old manual second-hand car.
Any Accent owners here? I've been driving mine for over ten years without any issues. It just gets better with time. Even though I've bought a new car, I still can't let go of my old friend!
My Previa's remote key won't unlock the doors, even after changing the battery. What's going on? Fellow car owners, can you please advise on how to fix this? Thanks a lot!
4My 207 keeps burning out the starter motor. In the past year, I've already replaced two, and today it burned out again, even started smoking. It feels like just replacing the starter motor isn't solving the root problem. Any fellow car enthusiasts know how to fix this?
5Hey guys, is your steering wheel heavy? Mine feels a bit heavy. How can I fix this?
6Has anyone experienced oil leaks? My car has only 9,000 kilometers, and during maintenance, they found the valve cover was leaking. It took a week, but I finally got it back from the dealership today 😂. I asked some fellow car owners, and it seems there's a certain chance of this issue occurring 😂. It feels like Subaru's quality control is really lacking!
7Hi everyone, I want to ask if your Range Rover feels jerky at low speeds? Why does mine feel noticeably jerky? Also, there's some wind noise on the driver's side, and a bit of rattling on uneven roads in the back seat. Did I get a real Land Rover? 😎
8Fellow car enthusiasts, how often do you replace your solenoid valves? Mine needs replacing every year, and this year I've already replaced two.
9I've heard that the vacuum pump on the Jeep is leaking oil. I've already replaced two gaskets, but it's still leaking. I've been told that I might need to replace the entire assembly. Is that true? Can fellow car enthusiasts share their experiences?
10Hello CHR owners, what tire pressure do you usually maintain, around 2 point something? For summer and winter, I'd appreciate some guidance from fellow owners! I inflated mine to 2.6 the other day, is that a bit high?
