خالد عبد الحكيم
2024-11-26 16:29
Hey guys, have you changed the headlight bulbs on your RAV4? Or did you replace the whole headlight assembly? I always feel like the headlights aren't bright enough.
فهد نور الله
فهد نور الله2024-11-28 11:51
Change car.
عبدالرحمن يعقوب
عبدالرحمن يعقوب2024-11-28 11:30
Only the lens can be replaced.
عمر قاسم
عمر قاسم2024-11-26 18:52
Replaced the projector headlight.
I feel like the headlights aren't bright enough, especially the high beams. Do any fellow car enthusiasts know of any parts I can replace them with?
Hi everyone, I'm looking to upgrade the halogen headlights on my 2014 Yizhi to LED ones because they're not bright enough. Any good recommendations? Thanks!
Does anyone feel that the headlights of the Yaris X are not bright enough? Has anyone modified the headlights, and are there any compatible headlights available now?
Is the headlight of the 2019 Changan Alsvin automatic a combination of low and high beam, or are they separate? I'm thinking about changing the bulb recently!
Hey folks, are your car lights bright enough? I'm thinking about changing mine because they don't seem bright, but it looks like I have to remove the entire headlight to do it. Has anyone done this before? Any advice?
I bought a used 2018 Peugeot 3008 and feel like the halogen lights aren't bright enough. I replaced them with LED bulbs, but the light is still scattered and not good. Could you suggest what bulbs I should use? Also, does the original car come with projector lenses?
Hi guys, my 2014-2015 old Skoda Rapid's headlights aren't working. How did you guys solve this issue? Any good suggestions?
What bulbs have you all changed the lights of the Arrizo 5 to?
Can the daytime running lights be replaced separately? I modified the headlights, and it seems like the daytime running lights got damaged; their brightness isn't enough. It's a 2009 model.
Could you recommend a car light? I feel like my current ones aren't bright enough.
Toyota Toyota RAV4
Toyota RAV4AED 99,900 ~ 152,900Gasoline & Hybrid
