Has anyone upgraded the shock absorbers on the 24 model? Heavy-duty shock absorbers. Right now, even without much load, the truck sags, with only two fingers' width from the tire. It's too low. Any recommendations for heavy-duty shock absorbers to raise it?
I just bought a small Volvo, 2008 model. The condition is pretty good, but the shock absorber springs are too hard. Have any of you experts replaced them, or know which other cars have compatible parts? Thanks!
Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
4Are there any upgrades available for the Legacy's shock absorbers? Can you recommend any brands?
5Is there any car owner experiencing a noise from the right rear wheel? When the temperature is low, there's a squeaking sound when going over speed bumps. There's no abnormality during normal driving, and it doesn't make noise on bumpy roads. The shock absorber isn't leaking either. The car is only three years old, so it shouldn't be the stabilizer bar bushing issue, plus the sound doesn't seem like it's from the stabilizer bar bushing.
6Has anyone here ever changed the front shock absorber top mount on an Ertiga by themselves? Is it possible to replace the front shock absorber top mount without removing the shock absorber itself? How do you get the top mount off? Any guidance would be appreciated. [Embarrassed face]…
7I have a 2018 Outlander 2.4 AWD. Last month, the right front wheel got hit, and I had to replace the shock absorber, half shaft, and steering rack. 😒😒😒 Now, when I'm driving at around 110 km/h, the steering wheel vibrates in my hands. It's not exactly a shake, but more of a tingling feeling. The car doesn't drift or vibrate, just the steering wheel. If I grip the wheel tightly, it feels a bit better. There's no issue when driving below 100 km/h. I've done wheel alignment, and the data is spot on. I've also done wheel balancing and swapped the front and rear tires. I've even replaced the front bearings, but there's no change. The repair shop said the next step would be to start replacing parts one by one, but that would be too costly. Does anyone know what the problem might be? I'd be willing to offer a small reward for a solution. 😏😏😏
8How much does it cost to replace the front right shock absorber on a 2019 GS5? Should I replace just one or both? 😢
9I have a 2016 automatic model, and when driving on good roads, I hear a clear "clanging" sound from the right front tire area. Could this indicate a problem with the shock absorber? I just bought this second-hand car, looking for advice.
