Does the 2023 RAV4 still have rear tire wear issues?
Comments( 6 )
I've been using the 2017 MDX for over a year, and the front tires are wearing out unevenly. After rotating the rear tires to the front and doing an alignment, the newly replaced tires are again showing severe uneven wear. Have any other car owners experienced this situation? Looking for advice.
Can a wheel alignment be done if the rear tires of a 2015 Sportage are wearing unevenly?
4Are there still many issues with the engine overheating and cracking in the 2023 Vito?
5My Kodiaq's rear inner tires are wearing unevenly and noticeably. The repair shop says the lower arm needs to be replaced because it's not an adjustable one, so four-wheel alignment can't be done. Does anyone know if this is correct?
6My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
7How do I reset the tire pressure after a repair? It still shows low pressure on the right rear tire.
8Does the 2023 1.5L model have a particulate filter?
9Does the 2023 Leading Edition have loudspeakers in the rear doors?
10Are there any fellow drivers experiencing severe rear tire wear? After 30,000 kilometers, the rear tire treads are down to the warning line...
