حسن شجاع
2024-11-05 11:33
Does anyone else experience throttle vibration around 2000 RPM with the RAV4 petrol version?
عبدالله شمس
عبدالله شمس2024-11-22 23:01
Yes, same situation, there's a loud rumbling noise.
حسن شجاع
حسن شجاع2024-11-05 18:23
Does anyone else have the same issue? Is it a common problem or something unusual?
2
Hey guys! Does anyone else experience weird noises when their car's RPM goes above 2000? It sounds like a roaring noise, and I feel like it might be an issue with the intake or exhaust!
Hey folks, does anyone with a Multivan experience this? When starting from a cold engine, there's a huge vibration coming from the rear. The noise is really loud, but it goes away once the RPM drops. Does anyone know what's going on?
I just got a 2013 model with a 1.6 manual transmission. Everything else is fine except there's a loud buzzing vibration sound around 2000 RPM in every gear. Before or after hitting 2000 RPM, it's normal again. Has anyone else experienced this? How can it be fixed? Any advice from the experts would be appreciated.
The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵‍💫 Do any other T-Cross owners experience this situation?
Is anyone else experiencing noticeable idling vibrations? 😂 Just got the car, and it drives smoothly, but the idling vibrations are quite strong. Is anyone else having a similar issue?
When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
The 10-year-old 1.5 manual car experiences severe vibration in the gas pedal at 3000 RPM in any gear, making it difficult to press. Does anyone have a solution for this issue?
Does anyone else experience their engine roaring at 2000 RPM?
What's causing the accelerator vibration in the 2017 Compass? Does anyone else have the same issue?
Toyota Toyota RAV4
Toyota RAV4AED 99,900 ~ 152,900Gasoline & Hybrid
