حسين صلاح الدين
2024-05-24 19:02
Does anyone else experience their engine roaring at 2000 RPM?
Comments( 10 )
خالد عبد الحكيم
خالد عبد الحكيم2024-12-02 15:45
I suggest you give it a try. I feel it's okay. Music at speeds over 100 is still acceptable.
عمر مراد
عمر مراد2024-12-02 15:27
It's not right if I don't shout [I want to be alone]
حسن حمد
حسن حمد2024-12-02 15:17
[Agree] Same here.
نايف جعفري
نايف جعفري2024-12-02 11:59
Above 2000 RPM, it almost starts roaring. [I want some peace]
عبد لطيف أحمد
عبد لطيف أحمد2024-12-02 11:49
Yes, at 2000 RPM the noise is quite loud and muffled. If you press the pedal further, there's even a bit of engine roar. [I want to be quiet]
حسين عبد عزيز
حسين عبد عزيز2024-05-25 13:11
All set!
علي ياسر
علي ياسر2024-05-25 12:49
This car is just like that. Step on the gas and the engine roars, but the car doesn't move [I need some quiet time].
حسن بوتفليقة
حسن بوتفليقة2024-05-25 11:47
Congratulations on buying a real RAV4! 😄
عمر فاطمة
عمر فاطمة2024-05-25 10:56
That's called exhaust sound.
خالد مساعد
خالد مساعد2024-05-25 10:33
Just call it a day. 😁
Hey guys! Does anyone else experience weird noises when their car's RPM goes above 2000? It sounds like a roaring noise, and I feel like it might be an issue with the intake or exhaust!
Hey folks, does anyone with a Multivan experience this? When starting from a cold engine, there's a huge vibration coming from the rear. The noise is really loud, but it goes away once the RPM drops. Does anyone know what's going on?
Hey folks! Anyone else experiencing this with their Yizhi? What's the issue with the idle speed fluctuating when starting a cold car? Sometimes it hits 2000 RPM right after starting.
When the RPM reaches 2800, there's a loud roaring noise, but after 3000 RPM it disappears. What's going on? [Cover face]
I just got a 2013 model with a 1.6 manual transmission. Everything else is fine except there's a loud buzzing vibration sound around 2000 RPM in every gear. Before or after hitting 2000 RPM, it's normal again. Has anyone else experienced this? How can it be fixed? Any advice from the experts would be appreciated.
The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵‍💫 Do any other T-Cross owners experience this situation?
When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
Does your engine also make a loud noise when the RPM reaches 2000? Especially when going uphill, all I can hear is the roar of the engine.
Does anyone else experience this issue with the Hongqi H7 1.8T? In the summer, when stuck in traffic, turning on the air conditioning for a few minutes causes the engine to show high temperature.
Toyota Toyota RAV4
Toyota RAV4AED 99,900 ~ 152,900Gasoline & Hybrid
