The windshield washer spray on the Rapid is too coarse and too low, spraying below the wipers. How can I adjust it to be finer and higher?
The washer fluid on my Rapid is spraying too coarse and too low, hitting below the wiper blades. How can I adjust it to spray finer and higher?
4How can I adjust the headlights to aim higher? The low beams are too low on my 2018 1.8T model.
5What could be the reason for the windshield wipers not spraying water? Can someone with experience explain this?
6Which button on the Ghibli can spray the windshield washer fluid? I've tried the wipers, they work, but I don't know how to spray the fluid. Can any fellow car enthusiasts tell me? Thanks!
7How long can windshield wiper blades last?
8BYD Song Plus 2.0 Fuel version, the windshield washer fluid doesn't spray out, but after driving for a while, it starts working again. What could be the problem?
9How do I adjust the low beam height on the Hongqi H7? It's too low. Also, how do I use the headlight washer? Waiting online for help from fellow car enthusiasts. 🙏
10The windshield washer isn't spraying water, even though the tank is full. Does anyone know what's going on? Do I need to go to the 4S shop to fix it?
