حسين شعبان
2023-11-13 12:53
The washer fluid on my Rapid is spraying too coarse and too low, hitting below the wiper blades. How can I adjust it to spray finer and higher?
أحمد منتصر
أحمد منتصر2023-11-18 22:02
Use your hands to pull it apart.
How do I adjust the low beam height on a Peugeot 207? It's too high and keeps blinding other drivers at night.
The windshield washer spray on the Rapid is too coarse and too low, spraying below the wipers. How can I adjust it to be finer and higher?
How can I adjust the headlights to aim higher? The low beams are too low on my 2018 1.8T model.
Which button on the Ghibli can spray the windshield washer fluid? I've tried the wipers, they work, but I don't know how to spray the fluid. Can any fellow car enthusiasts tell me? Thanks!
BYD Song Plus 2.0 Fuel version, the windshield washer fluid doesn't spray out, but after driving for a while, it starts working again. What could be the problem?
How do I adjust the low beam height on the Hongqi H7? It's too low. Also, how do I use the headlight washer? Waiting online for help from fellow car enthusiasts. 🙏
What could cause the 2014 Peugeot 308 to not spray windshield washer fluid? Is it the lever on the right side of the steering wheel that needs to be lifted forward for a few seconds? I can't find the spray nozzles, so I'm considering using a needle to check if they're clogged. Any advice from the experts?
Why does the windshield washer fluid in my 2024 Arrizo 5 run out after just spraying three to five times? I've refilled it three times in a month and used it only about 10 times in total, each time just 1-2 sprays. Could the bottle be leaking? 😂😂😂
