Just had the 2019 automatic Rapid standard serviced and filled up with a tank of gas, then the engine fault code appeared. Has anyone else experienced this?
After replacing the battery in the MDX vehicle, a fault code appeared, and it cannot start.
My car had a minor collision and was repaired, but the alignment wasn't done. The steering wheel is off-center. After driving for a while, an error code appeared, indicating that the stability control system needs repair. A diagnostic showed that the steering wheel position is incorrect. After clearing the error code, it came back after driving for a while. Can any experts advise on what the issue might be?
Has anyone replaced the central control system on cars after August 2019? If you removed the original system, did it trigger an engine fault code? How did you resolve it?
4What are the issues when the warning lights for these fault codes appear on a 2015 MG GT?
5My car failed to start twice, and various fault codes appeared. The diagnosis showed that the ambient light fuse was blown. Have you guys experienced this? How did you solve it?
6Just had the 2019 automatic Rapid standard serviced and filled up with a tank of gas, then the engine fault code appeared. Has anyone else experienced this?
7My car is 3 years old and sometimes it shows a right front indicator fault, but then the warning disappears. I've had it checked at the shop, but they couldn't find the cause. Has anyone else experienced a similar issue?
8Hello fellow car enthusiasts! I bought my ZS at the end of 2019, and it has driven over 120,000 kilometers so far. Recently, it started showing a fault code indicating that the catalytic converter efficiency is below threshold. Has anyone else replaced their catalytic converter? What was your experience? Thanks!
9The fuel tank of the Venza Hybrid Premium is labeled as 55 liters, but I can't even fill it up to 50 liters. How about everyone else's experience?
10Today gave me a scare! The light was green and suddenly a fault code appeared, and the car wouldn't move! Not sure what happened. I didn't have time to take a photo.
