In a 2019 manual vehicle, if the steering wheel buttons suddenly stop working and after resetting and reconfiguring, the buttons still don't respond, what could be the reason?
Why did the reverse gear suddenly stop working, but it was fine an hour later, on a Trailblazer?
What could be the reason for the start-stop system not working on the 2017 model?
4How do you open the horn button cover on the steering wheel of the 2019 GA6?
5In a 2019 manual vehicle, if the steering wheel buttons suddenly stop working and after resetting and reconfiguring, the buttons still don't respond, what could be the reason?
6To reset the oil light on an Acura RDX, follow these steps: 1. Turn the ignition to the "ON" position, but don't start the engine. 2. Use the steering wheel buttons to find the "Settings" menu on the display. 3. Navigate to "Maintenance Info" or "Oil Life" using the arrow buttons. 4. Press and hold the "Reset" or "Select/Reset" button until the oil life resets to 100%. Make sure to consult your vehicle's owner's manual for any model-specific instructions.
7Is the steering wheel still heavy on the 2019 S Classic model?
8How do I reset the trip meter on a 2016 V60CC? I watched a video yesterday that said to press the "O" button on the steering wheel control, and it worked yesterday. But today, it doesn't respond. Any advice?
9What could be the reasons for the Peugeot 3008's automatic start-stop function not working properly?
10Recently, the engine start-stop system suddenly stopped working, and I didn't turn on the AC. It's been less than three years and under 30,000 kilometers. Does anyone know the reason?
