I've driven nearly 40,000 kilometers and I'm thinking about changing the spark plugs. Which model should I choose between Bosch and NGK? I saw a Bosch double platinum spark plug online. Is it necessary for this car to use double platinum?
Hello everyone, has anyone experienced this with the 2019 model 35p automatic? Currently, I've driven 60,000 kilometers, and occasionally when I brake at a red light, the idle speed fluctuates. How did you deal with it? I've cleaned the throttle and replaced the spark plugs, but I still don't know why it's happening.
I have a 2017 1.4T with all-wheel drive, driven over 60,000 kilometers in 5 years. When I accelerate to 60-80 km/h, there's a severe jerking, and it's slightly noticeable around 110 km/h too. I've changed the spark plugs and transmission fluid, and checked the engine mounts, but it hasn't helped. No error codes are showing up. Anyone else experiencing this issue? It's really frustrating to drive like this. I've been to several repair shops, even the dealership, and they suggested taking apart the transmission for inspection. 😖😖
4The 2022 Haval H9 is approaching 40,000 kilometers, and I'm not sure how much longer the original spark plugs will last. Fellow car enthusiasts, at how many kilometers did you change your spark plugs? What condition were the spark plugs when you replaced them? Thanks! ***** Also, I've clearly stated it's the Haval H9 and posted this in the Haval H9 section. Please make sure it stays within the Haval H9 circle and not other H9 circles. It's really tiring, you're quite something! *****
5I've driven nearly 40,000 kilometers and I'm thinking about changing the spark plugs. Which model should I choose between Bosch and NGK? I saw a Bosch double platinum spark plug online. Is it necessary for this car to use double platinum?
6I'm thinking about changing my spark plugs recently. What brands do you guys use?
7Yesterday, I went for maintenance and replaced the spark plug assembly. I want to ask, after a year and having driven 20,000 kilometers, is it necessary to replace it?
8Hey everyone, the AC isn't blowing any air, and there's no air coming out on internal circulation, only natural airflow. Have you encountered this before? Is it the blower that's broken? I saw online that there could be many reasons. Is it necessary to replace the blower with an original one?
9Is the lack of power when going uphill and the rise in RPM without an increase in speed in your fuel-powered Song Plus due to a spark plug issue? It's only driven 19,000 kilometers.
10Hello everyone! Is it necessary to change brake fluid every 40,000 kilometers? How should I choose brake fluid? Which brand should I choose?
