عبدالرحمن نوري
2023-11-12 15:10
I last changed the oil in August last year and have driven less than 10,000 kilometers since then. Do I need to change the oil now, and what's a good type to use?
عبدالرحمن هاماوي
عبدالرحمن هاماوي2023-12-01 22:09
It's time for a change, it's been over a year.
خالد أيوب
خالد أيوب2023-11-20 02:56
There are maintenance package deals, but if there aren't any, you can buy a Hong Kong version Shell 5W-40 on JD. Normally it's around 140, but during promotions, it's about 120. You can buy a spark plug, air filter, and oil filter yourself, and book a service on Meituan to get it changed at a shop.
محمد رجب
محمد رجب2023-11-12 15:31
Change it, 400 or 500 will do.
Should I change the transmission oil for an automatic car that's been driven for 11 years?
Hey fellow car enthusiasts, good afternoon! I've got a question for you all. What type of fuel do you usually use? I've been using Shell since I got my car and have driven over 10,000 kilometers. Now, I'm considering switching to Sinopec or PetroChina. Which one would you recommend? Thanks!
Is anyone selling a 2019 720S Coupe with less than 10,000 kilometers?
What could be the issue if the auto start-stop feature on a 3.0 Grand Cherokee hasn't worked since I bought it less than a year ago?
Can the original engine oil of the 90 Zilong Edition last for 10,000 km before needing a change? Changing it every 5,000 km seems too frequent.
How much and what type of oil should I use for a Cetus oil change?
I've driven my 2024 Wrangler for 10,000 kilometers. The first service was done at the 4S shop at 5,000 kilometers. They suggested I service it again at 10,000 kilometers. Do I need to change the engine oil this time?
Does your 1.6 naturally aspirated engine consume oil too? Mine has only run about 90,000 kilometers, and after the last maintenance, I drove less than 2,000 kilometers before the oil light came on. When I checked the oil dipstick, it couldn't even reach the oil level.
Do you use fully synthetic or semi-synthetic oil for your 10,000 km oil change?
