I bought a 2023 Lavida Star Edition in July. Last week, I accidentally noticed a strange noise around the right rear tire about six minutes after turning off the engine. Friends, do you know what might be causing this?
Guys, my order was delayed until the end of 2022 or early 2023 last week. Did you guys get any updates? 😢
MG3 2013 model 1.3L manual. Around July last year, the clutch wouldn't spring back, so I replaced the clutch kit. Recently, with the hot weather, the issue has reappeared several times. When the car heats up, the clutch rebound is particularly slow, and after a while, it won't rebound at all. If I park by the roadside for a bit, it gets slightly better. There's also a strange noise when pressing the clutch.
4I just bought a car and feel like I really can't drive it [facepalm]. I accidentally rev it too high. How many RPMs do you usually shift at? Before looking at the owner's manual, I was shifting at around 5000 RPM. Now my display shows an average fuel consumption of 10.4, and after driving just over 200 kilometers, the fuel tank is empty. My goodness 🤦, I'm refilling the tank once a week now. So should I shift when the dashboard suggests an upshift? Can I just shift from fourth or fifth gear to neutral when stopping at a red light, or is it better to downshift to third gear before going to neutral?
