عبدالرحمن فخرو
2024-10-04 10:17
Can door handles freeze in winter? I haven't been there, so I'm not sure.
I'm not sure if I should buy a Lotus at this price range.
The mechanic said my radiator is leaking, but I haven't noticed any decrease in the coolant reservoir, and there haven't been any warnings on the dashboard. Should I replace the radiator now? Thanks for any advice!
I don't understand, so I'm asking. Earlier it was mentioned that the car delivery would be in July. Has the 2.0T model been delivered yet?
I'm currently driving a 330i, and I'm considering adding a well-handling SUV since I'm quite focused on handling. I've heard this car is pretty impressive. I have two questions I'd like to ask. I'm considering the S+. 1. How is the handling of this car? 2. Is it convenient for maintenance and repairs? I haven't really seen Lotus dealerships around.
Has anyone driven the S Performance and can talk about the handling differences compared to the 3P? I'm hesitating between the 2022 3P and the 2019 S Performance. The S seems to look cooler, but I'm not sure if the handling is as good as the 3P.
Hey fellow car enthusiasts, my car is over seven years old and I haven't changed the tires yet. It's only been driven 60,000 kilometers. The tires are slightly aging, but I haven't driven much in recent years. It's mostly parked in the basement, so it's rarely exposed to the sun. Should I change the tires? I'm planning a long trip and am a bit worried!
Does anyone know how to set up the feature where you can unlock the car by bringing the key close to the handle and lock the door by pressing the handle?
Can I adjust the rear axle height by myself? Can I handle it?
I've got a 2016 manual Vitara, and I've noticed marks on all four door screws. It's a used car, so I'm worried the doors might have been repaired. Do other owners have the same issue?
Landrover Land Rover Range Rover Velar
Land Rover Range Rover VelarAED 291,000 ~ 400,260Gasoline
