محمد حليم
2024-09-28 23:07
Anyone else experiencing occasional rattling noises from the 24 model's dashboard? It sometimes goes "dang dang dang," but when I take it to the dealership, the noise disappears and they can't find the issue.
عبدالله كريم
عبدالله كريم2024-09-29 06:55
Same issue, it's intermittent. Do I need to take apart the center console?
Is there anyone else experiencing a rattling noise from the left corner of the dashboard in a 2015 V40? I haven't been able to find the cause.
There's a rattling noise like a loose plastic shell when accelerating while driving, but it's not there when revving in neutral. The noise also disappears when you press the accelerator pedal down hard after accelerating.
Geely sometimes has no response when starting, but the dashboard and electrical components are powered. It happens occasionally. Is there a solution?
Guys, today I tried flooring it in Sport+ mode and heard a rustling sound that lasted about 5 seconds before disappearing. No error codes on the dashboard, and the car drives fine. However, when I parked and shifted to P, there was a continuous electrical noise. The noise disappeared after switching to neutral and back to P. Could there be an issue with the transmission? How should I check it?
Is there anyone who has experienced an occasional rattling noise while driving? It seems to be coming from the left rear door lock area, making a "da da da" sound.
My car is 3 years old and sometimes it shows a right front indicator fault, but then the warning disappears. I've had it checked at the shop, but they couldn't find the cause. Has anyone else experienced a similar issue?
I have a 2017 V60, and sometimes I hear a clicking noise from the chassis when driving at high speeds. The noise disappears if I lightly tap the brakes. I suspect it might be an issue with the brake system, but I've been to the dealership twice and they couldn't solve it. Has anyone experienced a similar problem? Any solutions would be greatly appreciated!
Hey everyone, I've got an issue with my 09 model. Sometimes while driving, there's a sharp "dang dang" sound coming from underneath the car. It comes and goes, and sometimes I can even hear it when idling. The repair shop mentioned it might be the exhaust pipe but then said it doesn't seem like it. They think it might be coming from the bottom of the engine. Have any of you experienced something similar?
Hey buddies, does anyone have a rattling noise from the passenger side dashboard? My car is from 2021 and has less than 60,000 km. It happens when I turn on the power, while driving, and sometimes even when it's off. The noise also appears when I turn on the AC and occasionally when using the wipers.
Land Rover Land Rover Range Rover Velar
Land Rover Range Rover VelarAED 291,000 ~ 400,260Gasoline
