حمدان عبدالرحمن
2022-08-13 13:23
When unlocking the car, the right headlight takes 30 seconds to turn on. Is this normal or is there an issue? 🤦‍♂️🤦‍♂️🤦‍♂️
خالد هلال
خالد هلال2023-01-12 23:39
Check the settings, and if there's no issue, it might be a wiring problem that needs repair.
My X95 manual's headlights have an issue. When I start the car and turn on the high beams, they don't work at all. But for a few seconds, they work fine. When the car is parked and I turn on the high beams, everything is fine. What could be the problem?
How do I turn on the headlights when unlocking the vehicle at night? The headlight switch is set to the auto position.
When starting a cold car, it should normally take about 2 seconds, but sometimes it takes 5 or 6 seconds. Does anyone else have the same issue? Last time, I replaced a solenoid valve under warranty, but it didn't help. The warranty is about to expire, and I want to fix the problem. I have a 2019 GAC GA6 Luxury Edition.
Ways to unlock the car without turning on the headlights?
How can I prevent the headlights from turning on when I press the unlock button?
1. Is it normal for the acceleration of the HiPhi Z model to be very slow, taking about 10 seconds to reach 100, when the battery is around 15%? 2. Is it normal for there to be noticeable wind noise inside the car when driving at speed? Asking fellow car enthusiasts for some answers. 🙏
The turn signal is intermittently malfunctioning. Most of the time, it fails when the headlights are turned on—there's no light or clicking sound. Once the headlights are turned off, it works fine again. Has anyone else experienced the same issue?
It takes a few seconds to start, what's the reason? But when I start it again, there's no issue.
What's going on? The car locks itself five seconds after unlocking.
Any brothers know why the car beeps for a few seconds when you turn on the power, but doesn't show any issues or faults?
Maserati Maserati Quattroporte
Maserati QuattroporteAED 499,000 ~ 829,000Gasoline
