نايف رائد
2022-08-20 21:05
When the windows are closed and the music is off, I can hear a faint ticking noise while gently pressing the accelerator in park mode. It seems to come from the center console, like a small motor vibrating. When I press the accelerator hard, the sound disappears. I can also hear it occasionally when driving at low speeds or when releasing the accelerator. The noise is noticeable when starting the car cold, and it feels like a metal-on-metal vibration or collision underfoot. Interestingly, after driving for a while, the sound goes away. However, if the car is stopped for a while and then started again, the noise returns initially but disappears after driving for a bit.
سعود طموح
سعود طموح2022-08-22 10:44
Carbon canister solenoid valve,
When driving over 80 km/h and releasing the accelerator, I hear a consistent humming sound from the engine compartment, similar to the vibration of a phone ringing. Any ideas on what this might be?
The clutch of my 2018 Foton Tunland E5 was recently replaced, but there's always a burning smell while driving. Additionally, there's a strange noise when I'm not pressing the clutch, which disappears when I do press it. What could be the cause of this?
I've been hearing a strange noise from the left side of the dashboard when I press the accelerator in the morning. It feels like a vibration. Have any of you experienced something similar? I'll upload a video next time.
There's a rattling noise like a loose plastic shell when accelerating while driving, but it's not there when revving in neutral. The noise also disappears when you press the accelerator pedal down hard after accelerating.
Is there anyone with a Levante experiencing a ticking noise when idling after warming up the car? The noise disappears when you press the accelerator a bit. What could that sound be?
What could be the issue if my manual Jetta's transmission makes a rumbling noise, but the sound disappears when I press the clutch?
Is it normal to frequently hear a low-frequency buzzing sound while driving the Taycan?
Is it normal for the brakes to apply themselves without pressing the accelerator while driving?
When releasing the accelerator, there's a rattling metal friction sound. What could be the issue?
Maserati Maserati Quattroporte
Maserati QuattroporteAED 499,000 ~ 829,000Gasoline
