Why is the 1.3T flagship version all blue? I see a lot of used cars and test drive cars online that are all blue, and only the lower trims are available in white.
Hey guys, how's the rear-wheel drive on this car? Haven't seen any reviews for the luxury rear-wheel drive model online yet. Test drives are only available for the top-tier version. I'm on a budget and torn between choosing leather seats or all-wheel drive.
I'm considering buying a used advanced version mainly for city commuting, but it will spend a lot of time in the parking lot. Since I've been living abroad for a long time, I'm not sure if I should buy a car. I think this car looks pretty good. Currently, the available used advanced versions are only in white and orange. Which color looks better? I want to make a decision remotely first, otherwise, I might not have options when I return home. Thanks, everyone.
4I see a lot of people online saying there are cars in stock, but many owners haven't received their cars yet. What's going on?
5I want to get the 2.5i flagship model. I'm wondering if this car's engine consumes oil. I've seen a lot of news online about Subaru engines consuming oil.
6Is there anyone here who bought the GS4 Max in 2024 and can share their experience? I just test drove it a few days ago and really liked it, but the online reviews aren't very positive. People are saying there are a lot of strange noises and minor issues, and that rust is a big problem. How does it compare to the Nissan Qashqai?
7Car enthusiasts, there's a set of test car parts available now: rear seats with electric adjustment and a full set of 14 loudspeakers, plus labor and wiring, all for 1.5. Is it worth it?
8For your first time driving a 09 Mazda 6, here are some things you might want to consider: 1. **Basic Checks:** Before you start driving, check the fuel level, tire pressure, and ensure all the lights are functioning properly. 2. **Maintenance History:** If possible, review the car’s maintenance history to ensure it's up to date with regular services. 3. **Test Drive:** Take the car for a short drive to see if there are any unusual noises or vibrations. 4. **Visit a Mechanic:** If you're unsure about the car's condition, it might be a good idea to visit a mechanic for a thorough check-up. 5. **Familiarize Yourself:** Get comfortable with the car's controls, like the brakes, accelerator, and steering. Remember, safety first!
9I'm asking about the new 009 model regarding the HUD issue. I'm 186 cm tall, and during the test drive, I noticed that the HUD display is not fully visible. The top part is cut off due to the angle. I've already adjusted the HUD to the lowest position, and my seat is also set to the lowest and a relatively back position. Even then, in a normal sitting posture, the top of the HUD is still a bit cut off, and I have to lower my head to see all the HUD information. Are there any other owners with the same issue? Also, can the 009's HUD display information from QQ Music, like selecting a song to play or displaying lyrics?
