The 2021 Qashqai has been parked for a long time, and the battery has drained. A friend's car was used to jump-start it, but it still won't start. What could be the problem?
Comments( 10 )
Hi friends, how long can your X70P battery last on standby when fully charged?
The original battery in your Haima S5 from 2016, manual transmission, has been in use for six years. After being parked for half a month, you jump-started it with a power bank and have been driving it 50 kilometers daily for a week, but it still remains in a discharged state. If the car can't start after being off for more than an hour, it might be time to replace the battery.
I bought the car in August 2020, and now it often won't start. Is the battery drained?
4Has anyone experienced a dead battery causing the anti-theft system to lock, and jump-starting didn't help?
5Is the battery of the 2020 ASX durable? Mine is only in its fourth year and it's already having issues with not starting and battery draining.
6Is there anyone else experiencing severe battery drain with their Hongqi H7? If I don't drive for four days, the car won't start due to significant battery loss.
7Guys, need some help. My Hongqi EHS9 460 Flag Enjoy suddenly has a dead battery today, but it was running fine yesterday. Jump-started it and went to the dealership for a full day check, but they couldn't find the problem. Has anyone experienced something similar? Any advice?
8If your T99's battery is seriously drained and loses power after just a week of being parked, there are a few steps you could consider: 1. **Check for Parasitic Drain:** Ensure that no electrical components are drawing power when the car is off. This might include lights, the radio, or other electronics. 2. **Battery Health Check:** Have the battery tested to see if it's in good condition. Sometimes, a faulty or old battery may need replacing even if the car has only run 12,300 km. 3. **Alternator Check:** Make sure the alternator is charging the battery properly when the engine is running. 4. **Battery Maintenance:** If the car is parked for long periods, consider disconnecting the battery or using a trickle charger to maintain the charge. 5. **Professional Help:** If the issue persists, it might be a good idea to consult with a professional mechanic to diagnose and resolve the problem. Dealing with battery issues can be frustrating, but these steps might help in identifying and fixing the problem.
9What could be the issue if the car shakes after being parked for a long time?
10Is it normal for a Cayenne's battery to drain to the point where it can't be charged after not being used for a month in the third year? After replacing it with a new battery, it drains after about 20 days of not being used. This has happened several times. Is this normal?
