عبد العزيز مروان
2024-11-30 22:39
If the 2021 Qashqai has been parked for half a year and won't start even after jump-starting, and you've decided to replace the battery, you might wonder if you can replace the start-stop battery with a regular one.
خالد أحمد
خالد أحمد2024-12-01 22:33
This is a start-stop battery, which requires a relatively large instantaneous current.
سعود اشرف
سعود اشرف2024-12-01 13:33
That's definitely not going to work. The manufacturers are way ahead of you; they've already blocked all the loopholes you can think of. 😬😬😬
خالد أنور
خالد أنور2024-12-01 11:00
The battery for the auto start-stop system tends to be more expensive, and it's generally better.
حسن سلمان
حسن سلمان2024-12-01 07:44
It's best to unplug the power when you're not driving.
فهد مكي
فهد مكي2024-12-01 07:24
No, the start-stop battery requires a higher current.
I wonder, for a pickup truck, not considering road restrictions, it seems like it wouldn't fit in a regular parking space, right? [Facepalm] [Facepalm] [Facepalm] Where do you park it after buying?
The original battery in your Haima S5 from 2016, manual transmission, has been in use for six years. After being parked for half a month, you jump-started it with a power bank and have been driving it 50 kilometers daily for a week, but it still remains in a discharged state. If the car can't start after being off for more than an hour, it might be time to replace the battery.
It seems like the car key is out of battery, and the car won't start.
Has anyone experienced a dead battery causing the anti-theft system to lock, and jump-starting didn't help?
What should I do if my ES300h's battery is dead after being parked for half a month?
I've had my 2021 Jeep Compass for three years now. Last year, it was parked for half a month during the New Year, and the battery died, so I replaced it. In March this year, it was parked for over 10 days, and the battery was dead again. I replaced it with a new battery, and in May this year, after being parked for 9 days, the battery died again. What's going on?
Looking to buy an affordable and practical external power source for jump-starting a battery. Any recommendations, guys? [pleading face]
Hey car enthusiasts, just wondering, will the car give a warning to replace the key battery before it runs out?
The battery couldn't start the car after 3.5 years and needed replacement, even though the auto start-stop feature was mostly off. Fellow car enthusiasts, when did you replace your battery for the first time?
If you leave the key in the ignition for too long without starting the car, it won't start. If the key is in the ignition for more than half a minute without turning the engine on, the key becomes stuck and you have to turn off the power and try starting the car again.
