I have a 2017 model Qashqai bought in 2019. This year, I went for the first inspection, but they said it couldn't be tested. Once on the line, the car couldn't be engaged; as soon as it hit 20, the speed dropped, but everything is normal when driving on the road, and there are no warning lights. Has anyone encountered a similar situation? Can you tell me the reason?
After the vehicle inspection, a series of warning lights for ABS, ESC, electronic parking brake, and hill-start assist light up. Usually, they don't light up when I start driving, but after a while, they do. I went to the repair shop to clear the fault codes once, but after driving 20 to 30 kilometers, they came on again. Does anyone know what the cause might be?
Jetur X70, 2020 model. I started having a coolant leak, and when pressure was applied, the leak point was found. The four-way valve was replaced, and the heating pipe and water inlet pipe were tightened. It was also discovered that the water pump was leaking, and eventually, everything was replaced. However, after refilling the coolant, the mechanic found that the engine temperature was high, but it drops as soon as the heater is turned on. They spent half a day but couldn't find the problem, and the car not being fixed has caused a lot of issues. Have you encountered this before? How did you handle it?
Hello everyone, I have a question: My Mazda 6 had the engine light and oil light come on after shifting to neutral while waiting at a traffic light. The idle was normal, but there was no response when I pressed the gas pedal and shifted to drive. After restarting the car, everything went back to normal. I went to the dealership, but they couldn't find any error codes. Has anyone experienced something similar? How can I fix it?
