Why won't the Prius shift gears or respond?
I'm looking to replace the gear shift boot. How do you remove the gear shift knob? Has anyone done it before? Customer service said to pull it hard, but I've tried with all my strength and it won't come off. Is there an easier way?
Why won't the panoramic image open? Clicking it doesn't respond, and it also doesn't switch to the camera when I put it in reverse gear. What's the reason?
4Is it a problem with the gearbox if sometimes the 4th gear won't shift down to the 3rd gear in a 2015 Honda City with a manual transmission? Waiting online for someone knowledgeable about cars to answer.
5Car enthusiasts: Sometimes when driving a small car, the D gear won't shift up. The RPM suddenly goes up, but the gear doesn't match. What could be the reason?
6Why won't the sunroof close, and why isn't the switch responding?
7Why can't I shift gears often after starting my new Defender 130?
8Does the S gear shift up and down? Why can it only be in 1st gear and not in 2nd, 3rd, or 4th gear?
9Today, my car suddenly won't start and won't shift gears. The screen displays a message saying "Please shift to P or N." Have any of you encountered this situation before? What's the solution? 🤦♂️🤦♂️🤦♂️
10Why is there an impact when shifting from R to D gear?
