Is the Yokohama A349 tread tire still in production as an original equipment tire? Will other tires of the same size affect fuel economy?
Can the spare tire on the RDX be replaced with a full-size rim and tire and still be installed?
Are you guys replacing your Yige's tires with the original ones or going for other brands?
Forum members: Will the fuel consumption be higher with original tires compared to switching to all-terrain tires?
4Do you have any recommendations for tires for the 2018 Nissan Patrol 4.0? I'm looking for something quieter and with better fuel economy.
5Is it still possible to buy a 2011 imported Compass with a 2.0 two-wheel drive? What's the fuel economy like? 😬
6Has anyone used the durable Pirelli Scorpion tires 285/45R20 for the Grand Cherokee? How's the performance and fuel economy? Thanks!
7I only replaced the front two tires, not the rear ones, and they're from two different brands. The tread patterns are quite different, and the load capacity and speed ratings aren't the same. Is this okay? Is there any risk? Do I need to replace the rear tires as well?
8After replacing the full-size spare tire on a Robin Hood, will the tire pressure monitoring system still function properly?
9For a 2024 Jeep Wrangler Sahara that's already fitted with 285 tires, but still feels small, what size wheel spacers would make it look more impressive?
10Is the original Giti tire on the Song Plus fuel version, second-highest configuration, a run-flat tire?
