How can I adjust the low beam on a 2012 Prius to be a bit higher? I've already set the interior adjustment to the highest and made the 10% adjustment under the hood, but it's still low... Also, is it possible to convert to LED using the car's original lens?
How can I adjust the high and low beam headlights inside the car?
How do I adjust the low beam height on a Peugeot 207? It's too high and keeps blinding other drivers at night.
The windshield washer spray on the Rapid is too coarse and too low, spraying below the wipers. How can I adjust it to be finer and higher?
4Can the low beam headlights of the 2010 Peugeot 207 be adjusted for height?
5How to adjust the low beam height on the GAC Trumpchi GS7?
6How can I adjust the headlights to aim higher? The low beams are too low on my 2018 1.8T model.
7I replaced a pair of LED bulbs on my car, but now the low beam and high beam look the same. Any tips to adjust them to be lower?
8The low beam is a bit low. Which setting is appropriate to adjust it to?
9The original halogen headlights on the Sharan were replaced with LED headlights, and they flicker during start-stop. Should I use 5054 to activate the xenon mode for the low beam to stop the flickering?
10For a 2012 Kia Sportage with integrated headlights, if adjusting the low beam to the right position causes the high beam to point at the treetops, does anyone know how to solve this? How can the high beam be adjusted lower without moving the low beam?
