علي نجيب
2023-03-18 16:30
When the car is idling, it feels like it's shaking, but when I shift to neutral, it doesn't. Does anyone know what might be the reason?
Comments( 6 )
نايف فخر دين
نايف فخر دين2023-08-16 09:09
The rubber mat is damaged.
يعقوبي عمر
يعقوبي عمر2023-05-22 00:14
The engine mount is aging.
نادر خالد
نادر خالد2023-05-06 06:27
Engine. Radiator. If there's an issue, take it to the repair shop for inspection.
عبد العزيز هكيل
عبد العزيز هكيل2023-05-04 15:23
Replace the engine mounts.
سعود أنس
سعود أنس2023-04-23 10:07
Take a look at the engine mounts.
نايف زكريا
نايف زكريا2023-04-04 06:58
Remove and clean the throttle body and idle air passage, and it should generally return to normal.
Is there a situation where it shifts to neutral by itself when reversing in reverse gear?
When shifting from reverse to neutral in the 2019 GA6, there's a vibration. What's causing this?
My car has been driven 90,000 kilometers since 2013. It's shaking when idling, and there's a jolt when shifting from Neutral to Drive. Has anyone else experienced this issue? Could it be time to replace the engine mounts?
When driving a 2021 model and releasing the accelerator, the vehicle shakes. Does anyone know the reason for this?
I have a 2019 Santana, and it's slow to accelerate and feels jerky when overtaking. Does anyone know what might be wrong?
The 2023 model 3.0 is shaking a lot at idle, and there's a buzzing noise when starting. Does anyone know what might be causing this?
My Pang Ge has suddenly started to shake at idle these past two days. Went to the 4S shop and changed the high-pressure fuel pump, checked other areas too. It doesn't shake when driving, doesn't shake when braking with gear engaged, but shakes when in neutral. It shakes as if I'm braking. Can any experts help me figure this out?
When starting the 2014 GS5 2.0 automatic, the car shakes for about 10 seconds. It also shakes slightly when shifting from neutral to drive. Does anyone know the reason? Thanks 🙏🏻
Toyota Toyota Previa
Toyota PreviaAED 132,200 ~ 144,800Gasoline & Petrol
