عبدالله نصر
عبدالله نصر
Jun 29
My Previa's remote key won't unlock the doors, even after changing the battery. What's going on? Fellow car owners, can you please advise on how to fix this? Thanks a lot!
Comments( 10 )
حسين عبد المجيد
حسين عبد المجيد2022-12-06 15:18
Is it possible that the remote suddenly stops working? Also, is it possible to start the engine with one button? (Probably not...) If neither works, it might be that the wireless pairing code of the remote has failed! It's simple... Hold the remote close to the one-button start for about 10 seconds. Then, without moving the remote, press the one-button start. If the engine starts, it means it's fixed!
علي مراد
علي مراد2022-12-05 22:54
You didn't shift into "Park" when you got out of the car.
أحمد أمين
أحمد أمين2022-10-21 17:19
The release motor for the middle door is broken.
سعود كامل
سعود كامل2022-07-16 01:23
My Odyssey had a problem with the key's battery. I tried using the spare key, and it worked, so I figured that was the issue.
حريري حسن
حريري حسن2022-07-11 20:52
There is a white controller inside the door that is broken.
محمد توفيق
محمد توفيق2022-07-08 00:46
Wipe the key with alcohol.
صابر سلمان
صابر سلمان2022-07-01 06:30
Please reset the program.
عبد العزيز عامر
عبد العزيز عامر2022-06-30 12:57
I've also had a few times where I used the mechanical key to start the car. Next time I used the remote key, everything was fine.
حسين فخرو
حسين فخرو2022-06-29 22:14
Use the mechanical key.
نايف أسامة
نايف أسامة2022-06-29 21:03
The button on the car's remote key might be broken.
The door won't open after unlocking.
It seems like your 2011 Phaeton is experiencing some issues with the remote unlocking and the keyless start system. Sometimes you have to use the mechanical key to lock and unlock the car, and the keyless start doesn't work. Occasionally, after using the mechanical key to start and then turning off the engine, the remote unlocking and keyless start work fine again. What could be the problem?
The car doors won't open in the morning, and the whole car is out of power. The reason is unknown. Could the experts please advise on the cause and how to fix it? Waiting for your help!!!
I disassembled the Peugeot 301 key and moved the chip to a new case, with the metal key separate. Now, the remote can unlock the door, but the metal key won't start the car. Could it be the key issue that's causing the car not to start?
It seems like the car key is out of battery, and the car won't start.
My Roewe Max RX5 remote suddenly can't unlock the car doors. Can someone please help me out?
Does anyone know how to fix the electronic remote for the Kia Sportage when it's not working? I can't even open the car door, and the battery is hard to find!
Has anyone replaced the key battery before? After I replaced the car key battery myself, I can remotely lock and unlock the doors without any issues, but the car won't start when I insert the key. The anti-theft system isn't connecting. Does anyone know how to solve this?
2014 Peugeot 2008 manual transmission, the remote key can't unlock the driver's door (can open with the key), while the other three doors work fine. Any advice on how to solve this issue? 🙏🙏🙏
Toyota Previa
Toyota PreviaSAR 184,500 ~ 199,500Gasoline
