My 2002 Acr30's air conditioning has an issue. When I set the temperature above 18 degrees on either manual or automatic mode, it blows hot air, and there's an engine oil smell coming through. However, if I set it below 18 degrees, it blows cold air and the oil smell disappears. Has anyone else experienced this with their car, and how did you deal with it?
Hey everyone, just wanted to ask: Why does the JETOUR X95 blow hot air when I turn on the seat ventilation? Thanks!
4When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
5The voice system has no sound, but it can send commands. What's going on? Restoring factory settings doesn't work either.
6The temperature settings for both the driver and passenger sides are the same, but the passenger side is blowing hot air while the driver side is blowing cool air. What's going on, experts?
7My 207's automatic air conditioning is having issues. The air only blows towards the windshield and can't be switched to other directions. The display on the panel works, but it doesn't actually change. The AC compressor starts, but it keeps blowing hot air. The temperature adjustment panel shows the settings, but the temperature doesn't change.
8Is there anyone who has added rear air vents for a small car? It's really hot in the back seat.
9The AC in my 2017 Peugeot 308 starts blowing hot air after a while, and the fan near the radiator isn't working. What's causing this problem? Does it require major repairs?
10When I turn on the AC in my 2019 Taurus, the rear vents blow hot air. What could be the reason for this? Can anyone help explain?
