Is replacing the weatherstripping effective for water leakage on the driver's door frame of the ACR30?
Any fellow car owners experienced water leakage from the door seal?
How to deal with water leakage from the rear spray nozzle of Jimny?
There might be an issue with the seal or a blocked drainage that is causing water to accumulate under the driver's seat. It's best to check for any leaks in the door seals or windows, and also inspect the drainage system to ensure it's not clogged.
4I've never encountered an issue with high water temperature in my car. There's no water leakage. What could be the problem?
5Will the shark fin on the 2023 Lavida loosen and cause water leakage?
6Hi everyone, has anyone experienced water seeping into the back seat after heavy rain? I can't find the cause, and there are no signs of leakage.
7Is replacing the weatherstripping effective for water leakage on the driver's door frame of the ACR30?
8How to fix a drafty driver's door?
9Has anyone replaced the door seals? How's the effect? The wind noise is getting louder.
10How to remove the door panel for the driver's side due to noise?
