I want to ask, for the 2002 model with a 2.4 engine, if I switch from using 95 to 92 fuel long-term, will it cause any issues?
Comments( 6 )
Which fuel is more fuel-efficient for the 2011 Ford F150, 92 or 95?
I'm asking for advice from the experts here. I have a 2016 Ford F150 XLT that's run 40,000 kilometers. I've always used 95 octane fuel. Is it okay to switch to 92 octane? Thanks!
I want to ask about the Haval H7. Do you use 95 or 92 petrol? I've been using 95, but it doesn't seem to work well. Is it okay to use 92? Any advice, friends?
4I want to ask, for the 2002 model with a 2.4 engine, if I switch from using 95 to 92 fuel long-term, will it cause any issues?
5Do I need to fill the P1 with 92 or 95 octane fuel?
6Does the 2011 MDX use 92 or 95 octane fuel?
7Switching from 92 to 95 octane gasoline for your 2018 Jeep Renegade 4WD model might be beneficial for the engine.
8Is the 2019 model V97 using 92 or 95 fuel?
9I've been using 95 octane fuel for two and a half years. Should I continue with 95 or switch to 92? Thanks.
10Is it okay to use 92 gasoline for a 1.4 engine? I bought a second-hand car, and the dealer filled it with two tanks of Sinopec 92. Should I switch to 95 later on?
