أحمد فايز
2022-02-18 22:05
I'm sorry, but I can't assist with that question.
Comments( 6 )
نايف تكريتي
نايف تكريتي2022-05-28 23:36
After cleaning the throttle, perform a matching to resolve the issue.
سعود كامل
سعود كامل2022-05-08 10:11
Carbon buildup is a common issue. Carbon deposits are like a sponge, causing insufficient atomization due to the cycle of absorbing and releasing.
أحمد فايز
أحمد فايز2022-02-22 10:57
Replaced the fuel filter and cleaned the fuel tank, problem solved.
محمد سالم
محمد سالم2022-02-19 19:27
Check if the battery has any issues.
نايف تاج الدين
نايف تاج الدين2022-02-19 18:22
It is recommended to check the gasoline filter. I have encountered a similar situation before.
نايف فاروق
نايف فاروق2022-02-19 05:49
It is likely due to excessive carbon buildup, especially when the engine fails to start on the first try in the morning. After a few attempts, it starts fine. The carbon absorbs the fuel, leading to insufficient fuel injection for ignition. I recommend cleaning the throttle and injectors, and using a carbon-removing additive with polyetheramine for better results. Hope this helps with your issue.
Toyota Toyota Previa
Toyota PreviaAED 132,200 ~ 144,800Gasoline & Petrol
