حسن نوح
2024-05-09 14:36
Will using 95 instead of 92 in the 2700 engine improve power response? Has anyone tried it? Please share your objective opinion.
عمر أسد
عمر أسد2024-07-18 21:12
Naturally aspirated engines should use 92 gasoline. For the new turbocharged Prado, even if you want to use it, you can't.
علي أنس
علي أنس2024-07-17 12:27
The 2700 engine mainly has a low compression ratio, which makes it durable and reliable. You can use 90 octane fuel without any issues, it's not picky. In fact, using 98 octane fuel might not burn as efficiently. I've driven my 2700 for 620,000 kilometers without any problems.
Toyota Toyota Prado
Toyota PradoAED 199,900 ~ 264,900Gasoline
