فهد نبراس
2024-09-06 07:08
Will there be a pure gasoline version?
Comments( 7 )
أحمد حريري2024-09-21 07:05
There are 2.4T petrol, 2.4T hybrid, 2.7 naturally aspirated, and 2.8 diesel options. Other than the diesel version, I wouldn't recommend the petrol versions as their power is quite weak.
حسين ظافر2024-09-20 20:06
Even if it exists, I don't recommend it. The cost-performance ratio is too poor. It's definitely more expensive than the dual-engine, and not just by a little bit.
عبدالرحمن عبد الرحمن2024-09-18 13:44
The platform supports 2.7 (over 30 years old, even older than me), 2.4T, 3.5T, and 2.8T diesel. It depends on which FAW prefers. There's a higher possibility for 2.7 and 2.4T. There's also a chance for the 2.0T used in the Highlander. Actually, the best option is the 2.8T diesel, but it's also the least likely.
حسن صعدة2024-09-12 14:46
The 2.8t diesel Middle East version is now priced at 70 for the mid-range and 96 for the top-range at the port. Would you buy it?
سلمان وحيد2024-09-08 13:55
Isn't this just the pure gasoline version? Can it get a blue license plate?
20
عبد العزيز زيد دين2024-09-07 08:03
What is the pure fuel version?
عمر مأمون2024-09-06 09:59
Parallel Import
I'm considering purchasing a corporate version of the Lavida pure electric. Is it available?
Is there a gasoline 4WD version for the 2019 SAIC Maxus?
Pure electric platform or gasoline-to-electric conversion?
4Does this car have a gasoline version?
5Does the Hongqi HS9 have a gasoline version?
6Why not release a purely fuel-powered version?
7Should I buy a pure gasoline version or a hybrid version of the Lingfang?
8Will there be a pure gasoline version?
9Will there be a 2.4T pure gasoline version of the Prado?
10Does a pure gasoline car have a particulate filter?
