فهد معتصم
2024-10-05 16:22
Why is there an impact when shifting from R to D gear?
نايف ثمين
نايف ثمين2024-10-11 19:09
It's one of the souls of fuel-powered cars, the mechanical feel.
The gear shift light for the 150 isn't working. Could it be that a button hasn't been turned on? The P, R, D indicators don't light up at night when the car is running.
I need help from everyone. When shifting from neutral to D gear, there's a noticeable jolt. What's causing this issue? Thanks a lot!
I want to buy a Kia Pegas for commuting, but I've heard from friends that when driving in D gear, you need to come to a complete stop to shift into 2nd gear. Is it really that troublesome?
Why does the Changan Yuexiang jerk when starting in D gear?
MG HS experiences a strong jolt when shifting from P to R or D when the car is cold. This has happened many times. When I went to the service center, the technician connected a computer and reprogrammed the transmission for gear learning. It got better, but after some time, the jolt returns when shifting gears with a cold engine.
What should I do about the gear shifting impact in the Yuexiang when it's fine when cold but jerks when hot?
When shifting from D to neutral, there is a clicking sound. What could be the problem?
Nissan X-Trail e-Power, I have two questions: 1) When the door is opened in D or R gear, the car alarms, but it doesn't shift back to P gear. Is that correct? I seem to remember it would automatically shift back to P gear before. 2) The speed-sensitive setting for the front wipers is on, but it doesn't seem to activate automatically when it rains. Why? Thanks for the explanation.
Toyota Toyota Prado
Toyota PradoAED 199,900 ~ 264,900Gasoline
