When the Prado 4.0 is between 40 to 50 mph, the steering wheel vibrates, and there's a humming sound.
Why does the car make a humming noise at 40 mph? The noise is very loud, and the shock absorbers have been replaced.
Are there any GV80 owners experiencing a vehicle vibration issue transmitted to the pedal and steering wheel at around 1500 RPM before each gear shift, while driving at a speed of 40-80 mph?
What could be the issue if there's a clicking sound from the steering wheel when idling?
4Hi, what could be causing the steering wheel to make a buzzing sound when turning?
5Is it normal to feel slight vibrations when sitting inside a Patrol 4.0 at idle?
6When you hear a clunking sound after turning the steering wheel, what's going on?
7When turning the steering wheel of the MG HS, there's a clicking sound on the left side.
8Why does the steering wheel vibrate while driving?
9Why does the Mazda 6 shake side to side when starting at 20-40 mph?
10Changan CS95 accelerates at 40-50 mph with high RPM but lacks power. What could be the issue?
