What type of engine oil should I add to my Prado 2700 that has run over 180,000 kilometers but doesn't burn oil? Thank you, everyone!
I bought a used Liana and it's burning oil. What should I do?
What type of engine oil should be used for a 2008 S40?
What type of oil should be used for a 1.5T engine?
4Hey fellow car enthusiasts, I just got an '09 Mazda2. I wanted to ask if there are any common issues I should be aware of. Also, is the Mazda2 prone to burning oil? I'm really concerned about the oil burning issue. Thanks!
5What type of transmission oil should I use for my Mazda 5? Planning to change it, thanks.
6Hello MDX car owners, how many liters of engine oil do you usually add during maintenance? How many kilometers can you run? I used Mobil this year, added 5 liters each time, but the oil is almost running out after just over 5000 kilometers. It's burning quite a bit, is this normal?
7What type of engine oil do people generally use for a newly purchased second-hand 2008 2.0? How often should the transmission oil be changed? Thanks!
8What type of engine oil should everyone use for maintenance?
9How much and what type of oil should I use for a Cetus oil change?
10What type of engine oil should I add to my Prado 2700 that has run over 180,000 kilometers but doesn't burn oil? Thank you, everyone!
