I've driven my LC250 for 2000 kilometers, and there's a squeaky noise when making a slow left turn or going over speed bumps. It's coming from the suspension area.
The 2014 Model S P85 makes a rattling noise from the right side of the chassis when going over small bumps, manhole covers, and speed bumps. I've already replaced the control arms, but the noise is still there. Does anyone else have the same issue? How can it be resolved?
4Help needed, the suspension of my V40 makes squeaky noises when getting in and out or going over speed bumps. I called for advice and they said it might be due to aging bushings. Has anyone else encountered this issue?
5It's uncomfortable going over speed bumps, it's very bumpy. What's up with the suspension?
6Is there anyone who has experienced an occasional rattling noise while driving? It seems to be coming from the left rear door lock area, making a "da da da" sound.
7Hello fellow car enthusiasts, has anyone installed coilover suspension on their car? Can it improve the chassis feel? My car is a 2017 4WD Elite with over 90,000 kilometers. When I go over speed bumps or drive on rough roads, the chassis makes a clunking noise. Will installing coilover suspension help?
8My car is a 2019 model, and I've driven many cars, but none of them make the hissing sound over speed bumps like mine does. I haven't driven other Kodiaqs. Is it an issue with my car, or do all Kodiaqs have this kind of suspension noise?
9Driving over speed bumps at 60 km/h can indeed have an impact on your car. It might cause stress to the suspension system, tires, and potentially the alignment. It's always best to slow down for speed bumps to avoid any potential damage.
10After driving the Venza over bumpy roads, there's always a strange noise coming from the trunk, like something is rubbing or hitting against each other. The same noise happens when turning or going over speed bumps. I've removed all the tools from the trunk and taken off the plastic covers, but the noise is still there.
