I've been following this car for a while and I noticed that its visibility is much worse compared to the old model. There's a big thing at the top center of the glass that really blocks the view.
To replace the gear shift boot on a manual 2018 MG ZS, follow these general steps: 1. **Remove the Gear Knob**: Unscrew the gear knob by turning it counterclockwise. Some models may have a clip or screw that needs to be removed first. 2. **Detach the Center Console**: Depending on the design, you may need to remove screws or clips holding the center console in place. Carefully lift the console to access the boot. 3. **Remove the Old Boot**: The boot is usually attached to the console with clips or staples. Gently detach it without damaging the console. 4. **Install the New Boot**: Secure the new boot onto the console by attaching it with clips or screws, ensuring it fits snugly. 5. **Reattach the Center Console**: Place the console back and secure it with screws or clips. 6. **Reattach the Gear Knob**: Screw the gear knob back on by turning it clockwise. Make sure everything is securely fastened and test the gear shift to ensure smooth operation.
