عبدالرحمن راضي
2024-03-11 22:32
I've always liked the style of the Prado with its spare tire on the back, but back then, I couldn't afford it. Now, the new model comes with a price range of 470,000 to 570,000 RMB. Considering today's car market and the current economic situation, spending over 600,000 RMB to get a Prado feels not worth it. Any tips or suggestions from you guys would be appreciated.
Comments( 9 )
حسين أكبر
حسين أكبر2024-07-24 12:26
Driving a luxury car for a few months feels the same after a while. Practicality and stability are key, and resale value is also important. You'll understand when you want to change cars after a few years. Plus, the high-end trim of the Prado has a decent interior. I've seen the actual car, and it's quite well-balanced. It's quite competitive at around 60!
عمر خلدون
عمر خلدون2024-07-23 23:05
I feel the same, I'm waiting for a price drop of 40,000 to 50,000 RMB. Or maybe I'll get a second-hand Defender 110.
عبدالله عفان
عبدالله عفان2024-03-13 23:55
The price in the US is similar to the X5, as it's a global model. [I want to be quiet]
نايف نور
نايف نور2024-03-13 22:52
This car is worth less than 350,000. The 2.4T engine, the classic interior, and the average looks with the Toyota badge make 350,000 a fair price. Why not consider the GLC or Q7 for 600,000? Is there any reason to choose the Prado? If you truly need it for construction sites, then ignore my comment. [Grin] In China, off-roading is definitely a niche demand.
علي سعد
علي سعد2024-03-13 00:11
This car costing over 40 is considered normal. If it's 60, then it's more about catering to the older generation's nostalgia. Personally, I think there are better options at 60.
نايف زياد
نايف زياد2024-03-12 20:50
Not worth it [I just want to be alone]
نايف إسحاق
نايف إسحاق2024-03-12 18:09
If you truly have the money, you can pay for nostalgia!
علي محمود
علي محمود2024-03-12 07:28
You can go check out the Tank 700.
خالد ق
خالد ق2024-03-11 23:03
Just don't buy it then [I need some peace].
If you're looking to buy a used car with a budget of 40,000 RMB and you've got your eye on models like Lavida, Sylphy, Sagitar, and Jetta, here's a brief rundown: 1. **Lavida (朗逸)**: Known for its reliability and decent fuel economy. Look for models from around 2012-2015 for a balance of price and condition. 2. **Sylphy (轩逸)**: Comfortable and spacious, good for city driving. Consider models from 2013-2016. 3. **Sagitar (速腾)**: Offers a solid driving experience. Models from 2012-2015 could be a good fit for your budget. 4. **Jetta (捷达)**: Durable and economical, a popular choice for many. Look for models from 2012 onwards for better features. For city commuting, all these options are suitable, but it ultimately depends on your personal preference regarding style, comfort, and brand loyalty. Make sure to check the car’s condition and service history before purchasing.
In March 2021, I had a 2020 model of the Leading Version. A few days ago, while driving on the highway with the AC on, everything was fine for about an hour. Then, it started getting hotter inside the car. When I checked, the air coming out of the AC vent was disappointingly weak. Usually, setting it to level 1 is more than enough to keep things cool, and sometimes I even have to turn it off for a bit. But this time, even when I turned it up to levels 3 or 4, the cold air was still too weak. Finally, I set it to the maximum, which was barely acceptable. At the same time, the noise from the electric fan became increasingly louder. Later, when I turned it back to levels 1 or 2, there was no airflow at all. Has anyone else experienced a similar issue? How should I resolve it? I would appreciate any valuable suggestions. Thank you.
Toyota Toyota Prado
Toyota PradoAED 199,900 ~ 264,900Gasoline
