محمد سالم
2024-10-29 01:34
I initially thought this was a powerful, spacious, comfortable, and well-designed crossover, but it turns out to be just a show-off car. The mid-to-low trims don't even have the necessary off-road features. Totally disappointing, Toyota really has changed.
حسين أمين
حسين أمين2024-10-30 23:48
I went to the 4S dealership today, and the back seat is really small.
20
نايف ميثا
نايف ميثا2024-10-29 10:03
All the off-road features are available in the mid to high-end models. Why complain about the low-end ones? Once you have enough money, all your needs are met.
Here’s the situation: I just replaced the battery, but it's dead again. After starting the car, after a while, it reports a battery charging fault. Then the ABS and airbag lights also come on. When idling in place, after a while, the car will automatically shut off. When driving, it feels like it doesn't shift gears automatically, and I can't switch to manual mode either. Vehicle: Peugeot 207 1.6 Automatic. The battery wasn't great initially, and I didn't pay much attention to it, usually jump-starting the car. A few days ago, I replaced the battery. First, during driving, it started showing a battery charging fault. After a while, the ABS light came on, then the airbag light lit up as well. It's like a parade of warning lights. Now I'm wondering if it's worth repairing. What could be the issues?
If you're looking for an SUV around 130,000 RMB for daily family use, Chery Tiggo 8, Jetour X90, and Haval Big Dog are all decent options. Here's a brief overview to help you decide: 1. **Chery Tiggo 8**: Known for its spacious interior and good value for money. It's a solid choice if you prioritize comfort and practicality. 2. **Jetour X90**: Offers a roomy cabin with flexible seating arrangements, making it great for family trips. It's also equipped with a range of features for convenience. 3. **Haval Big Dog**: Stands out with its unique design and off-road capabilities. If you enjoy a rugged look and some adventure, this might be the one for you. Consider what features are most important for your daily needs, like interior space, tech features, or off-road capabilities, to make the best choice.
If you're considering the Jetour X70, there are a few things to keep in mind. Here are some pros and cons based on general feedback: Pros: 1. **Design**: The Jetour X70 is often praised for its stylish design and aesthetic appeal, which seems to be one of the reasons you're considering it. 2. **Space**: It typically offers a spacious interior, making it comfortable for families and long trips. 3. **Features**: The vehicle usually comes equipped with a range of features that enhance comfort and convenience. Cons: 1. **Manual Transmission**: If you're looking at the manual version, consider whether you prefer this over an automatic, especially in heavy traffic conditions. 2. **Brand Recognition**: Jetour might not be as well-known as some other brands, which could affect resale value and brand trust. 3. **Performance**: Depending on your expectations, the performance in terms of horsepower and Fuel economy might not match some competitors. Overall, it's important to weigh these aspects based on your personal needs and preferences. If possible, test driving both the Jetour X70 and Jetour Dasheng could help you make a more informed decision.
Are you torn between the G80 and the Mercedes E? I'm currently driving an XC60, and honestly, Volvo's resale value in the domestic market is disappointing. I initially thought I wouldn't care and would drive it for 10 years, but the reality is that I'm planning to switch in less than 7 years. Considering the future resale value of the G80, I'm a bit conflicted.
Let me share my experience as well. I also have a 2017 MG ZS, one of the first batch from July, manual top configuration. Since then, apart from other issues, the main problem has been the car cutting off power when starting. The entire car loses power, and it won't start. It's fine today, but not tomorrow. The car often won't start. I've replaced several batteries and small parts, but the issue remains. Sigh, I'm disappointed. The car is still at the repair shop now, I'm afraid to drive it. If it stalls, it won't start again, which is frustrating. I used to be a loyal MG fan, but I'm really disappointed now. Next time I change cars, I won't choose MG anymore. Does anyone know what the problem might be?
Toyota Toyota Prado
Toyota PradoAED 199,900 ~ 264,900Gasoline
