For the Prado 120, when choosing a rear lock, should you go for an electric lock or an air lock? If you choose an air lock, you will also need to buy an air pump, right?
Do air locks really tend to leak? Maybe switching to an electric lock would be more stable. What do fellow car enthusiasts think?
I bought a Kia Sportage in 2010, and suddenly the right rear door won't open. What could be the reason? It's not the child lock issue. Also, the door handle feels loose when pulled.
If you're thinking about modifying your Jimny with a differential lock, should you choose an electric lock or an air lock? I've heard that the CJ brand's electric lock is forged. Is it worth purchasing?
4How did you solve the issue with the rear central air conditioning since the NV200 doesn't have central air conditioning?
5What could be the issue with the right rear door of a Jetour X70 not locking?
6Is there any leakage on the right rear D-pillar? Is it caused by the air conditioning pipe like the Land Cruiser Prado?
7The child lock on the right rear door of the 2014 V60 is not engaged, but the door cannot be opened from the inside, only from the outside. What could be the issue?
8For the Prado 120, when choosing a rear lock, should you go for an electric lock or an air lock? If you choose an air lock, you will also need to buy an air pump, right?
9Can the new mid-range Prado be equipped with a rear lock?
10Is the warm air blowing on the windshield of your LC120 also feeling weak? Is it the same for you guys?
