Are there any affordable 20-inch tires that fit the 718T? Specifically, front 235/35R20 and rear 265/35R20? I can't afford PS4 and PZ4 anymore.
Why can't I find the fuel economy display anymore? [Crying]
Are there any affordable and good loudspeakers to replace the front two?
How many kilometers did you guys change the tires for the 2021 C11 with 20-inch tires? What tires did you switch to? My original ones were Pirelli tires.
4Are there any affordable 20-inch tires that fit the 718T? Specifically, front 235/35R20 and rear 265/35R20? I can't afford PS4 and PZ4 anymore.
5I only replaced the front two tires, not the rear ones, and they're from two different brands. The tread patterns are quite different, and the load capacity and speed ratings aren't the same. Is this okay? Is there any risk? Do I need to replace the rear tires as well?
6Is it necessary to rotate the front and rear tires at 45,000 kilometers?
7Can the 2.0T Rui Shang be fitted with 20-inch wheels? Has anyone done it before? Please reply, thank you 🙏🙏🙏
8Hi everyone, I want to ask about the 2024 Cayenne. When I bought the car, there were no 21-inch wheels available, so I got the original 20-inch ones. Now I'm planning to change them. Should I go for the 20-inch bird's nest wheels or directly switch to 21-inch tires and wheels? I'm not very familiar with this. I've heard that 21-inch wheels might affect comfort and increase noise. A friend who repairs cars also says I don't need 21-inch wheels, but I'm worried I might regret sticking with 20-inch. Any advice?
9Has anyone here modified their car or changed tires? My left front tire got a nail in it and can't be repaired. I've been asking around but can't find a Toyo 225 55 R19 tire, and with the national holiday, I can't replace it until the 4th. It's really inconvenient. Has anyone switched to other tire brands after buying their car? Any recommendations? I'm hesitant to replace just one tire with a different brand, and since I need the car urgently, I'm considering replacing both front tires.
10Is there a problem if the tire pressures are different? Front left 240, rear left 250, front right 240, and rear right 233. Is it okay to drive?
