سعود سهيل
2019-06-01 20:28
How is the stability of the Polo?
Comments( 6 )
أحمد قربان
أحمد قربان2023-10-08 21:52
Why does the car still feel bumpy and uncomfortable even after changing to EDDY shock absorbers?
أحمد عَبْدُ الْعَزِيز
أحمد عَبْدُ الْعَزِيز2019-06-01 20:53
The Volkswagen Polo is a compact car with excellent quality in its three main components, resulting in a very low failure rate over time. Despite being a small car, the interior space is sufficient for family use. Additionally, it is quite fuel-efficient, consuming about six liters per 100 kilometers in urban areas.
أنس عبدالله
أنس عبدالله2019-06-01 20:43
The POLO is a compact car featuring a front MacPherson independent suspension and a rear torsion beam non-independent suspension. It offers impressive stability, with a well-tuned chassis and strong handling, making it ideal for city commuting.
عبد العزيز حمزة
عبد العزيز حمزة2019-06-01 20:43
Volkswagen cars are known for their excellent stability, and the Polo has been on the market in China for decades without any major issues. This makes the Polo very reliable and well-suited for city commuting.
نايف سعيد
نايف سعيد2019-06-01 20:43
You can tell from the appearance of the Polo that its stability is quite decent. As a compact car from Volkswagen, its performance and value for money are particularly good.
محمد فادي
محمد فادي2019-06-01 20:32
The Volkswagen Polo is a joint venture compact car known for its stable build quality and reliability. It has decent sales figures. In terms of power, it comes with 1.4T and 1.5L engines, with a fuel consumption around 7 liters per 100 kilometers.
Has anyone experienced a rattling noise from the front of an '08 Mazda 5 when driving on bumpy roads? I've just replaced the front shock absorber assembly, lower control arm, tie rod end, sway bar link, and stabilizer bar bushing, but the noise persists. Any ideas?
My car had a minor collision and was repaired, but the alignment wasn't done. The steering wheel is off-center. After driving for a while, an error code appeared, indicating that the stability control system needs repair. A diagnostic showed that the steering wheel position is incorrect. After clearing the error code, it came back after driving for a while. Can any experts advise on what the issue might be?
I bought a second-hand Kia Sportage that's 10 years old. When going over bumps or speed bumps, the front chassis makes a creaking noise. I asked a repair shop, and they said it's likely the stabilizer bar bushings have aged. Replacing the two front stabilizer bar bushings would cost over 200, but they also mentioned that changing them might not necessarily solve the problem. Do you think it's necessary to replace them?
Why is the stability control light on and the handbrake not working? Anyone else experiencing the same issue?
Hey folks, for mostly city driving with good fuel economy and stability, which year's model would you recommend?
Is there any car owner experiencing a noise from the right rear wheel? When the temperature is low, there's a squeaking sound when going over speed bumps. There's no abnormality during normal driving, and it doesn't make noise on bumpy roads. The shock absorber isn't leaking either. The car is only three years old, so it shouldn't be the stabilizer bar bushing issue, plus the sound doesn't seem like it's from the stabilizer bar bushing.
I want to ask everyone about modifying a Patrol and the experience of using aftermarket parts for a few years. How's the quality and stability? Especially the LCD instrument panel and central control screen, do they black out when reversing? I'm thinking about getting modifications done.
I've been driving a Peugeot 307 for over ten years and I'm ready to change cars. However, I feel like it's hard to find a car in the same price range that matches its safety, stability, and handling. Does anyone have any recommendations?
I would like to ask if the stability of the Peugeot 308 1.2T has improved a lot after the 2018 model? Or is it still the same as before, with issues like oil burning and cylinder scoring? Can any real car owners share their experiences?
How is the stability of the 2.0T Nissan Altima? Does it drift easily, and is the fuel consumption particularly high? How about the stability of the three major components, and does it tend to have many issues?
Volkswagen Volkswagen Polo
Volkswagen PoloTBDGasoline & Petrol
