محمد حازم
2020-08-16 00:17
Whenever I accelerate my Phaeton 3.6, there's a sound like metal clanking coming from the middle section of the exhaust pipe. I can't seem to fix it. I had it checked, and there's nothing wrong with the exhaust pipe. The dealership mentioned it's a common issue. Has anyone else experienced this problem? Any solutions?
Comments( 15 )
عبدالله دل
عبدالله دل2022-09-16 15:12
I always thought it was the catalytic converter issue [I want to be alone]
عبدالرحمن بكران
عبدالرحمن بكران2022-05-10 17:23
How do I weld? Which part should I weld to?
عبدالرحمن بكران
عبدالرحمن بكران2022-05-10 17:13
How did you all solve it?
عبدالرحمن مساعد
عبدالرحمن مساعد2022-01-12 02:28
Seeing so many of you guys have the same one as mine makes me feel relieved 😃😃😃😃😃😃😃😃😃😃😃 Mine is a 2011 3.6.
20
أحمد اشرف
أحمد اشرف2021-11-22 10:13
Exhaust resonance can be fixed by welding the two exhaust pipes together.
أمير محمد
أمير محمد2021-11-21 11:21
Same here... I'm too embarrassed to drive in the neighborhood. I took it to the 4S shop, but after a week, they still couldn't fix it.
علي زبيدي
علي زبيدي2021-11-03 06:42
Our cars have the exact same issue, but we just can't figure out where the problem is. Especially when refueling, there's this rattling noise.
حسن فيصل
حسن فيصل2021-02-04 07:11
I haven't encountered that before.
إلياس محمد
إلياس محمد2021-01-29 16:30
All Volkswagen models have this sound; it's not a problem.
20
نايف نبراس
نايف نبراس2021-01-19 17:52
With the 3.6, I often hear a tractor-like noise during startup phase. [I want to be quiet]
How do I connect Bluetooth to play music in a 2011 Phaeton 3.6?
Can anyone share a picture of the mid-section exhaust pipe for a 2015 GT with a 1.5T engine? Thanks!!!
Have any fellow car enthusiasts encountered a situation where the catalytic converter has minor cracks, causing occasional exhaust emissions to go uncatalyzed and triggering the emission warning light? The mechanic mentioned this. I regularly use Carpol's catalytic converter cleaner, Liquid Gold, etc., so there shouldn't be a carbon buildup issue.
Even after changing the middle exhaust pipe, the fault light is still on. What could be the reason?
Stainless steel shell thickness: 1.8mm for the four doors, 1.4mm for other parts. I was quite puzzled after watching a video of the actual car this year; it didn't seem to match the 3mm thickness mentioned in 2019. Today, I just saw a video explaining the official version of the sheet metal thickness.
Hi everyone, I have a 2016 3.6 Grand Cherokee. Recently, after switching to 0-20 oil, I've noticed a "doo-doo" sound coming from the exhaust area inside the car. It's not very noticeable when I get out of the car, seems like some kind of resonance. Also, after the oil change, the engine sounds louder. I've driven 400 km since then and there's no improvement. Any ideas?
Hey everyone, I've got an issue with my 09 model. Sometimes while driving, there's a sharp "dang dang" sound coming from underneath the car. It comes and goes, and sometimes I can even hear it when idling. The repair shop mentioned it might be the exhaust pipe but then said it doesn't seem like it. They think it might be coming from the bottom of the engine. Have any of you experienced something similar?
Is it true that you can't talk in the car while navigating? Whenever I mention a location or something else, it messes up the navigation or interrupts with random comments. What should I do? I really regret it!
I noticed occasional vibrations in my Murano at around 20,000 km, and the vibrations don't last long. When I went to the dealership for maintenance, they mentioned that they could replace the mid-section improvement part with a bracket for free. Has anyone had this replaced? How does it feel after the replacement?
