The suspension adjustment on the Phaeton works well in just one mode, but when switched to other modes like Comfort or Sport, the soft and hard adjustment light stays on.
My 2011 Comfort version has the AC on all the time, usually set around 26°C! The fuel consumption is around 10 liters. I hardly use the sport mode. Is there any way to reduce it to the 7-8 liters you guys mentioned? (I'm planning to change the engine oil to 30, as well as the transmission oil and spark plugs soon.)
How do you switch between the advanced mode and normal mode of the Phaeton's air suspension? In the advanced mode, is the front lower and the rear higher when parked? [Facepalm]
4Why does it sometimes feel like the brake and accelerator are hard when I start the car, and other times they're soft? It feels uncomfortable to drive when they're hard.
5When driving at high speed in the 2020 top-spec Legacy, I notice the suspension makes a "gugu" noise. I'm curious if others have experienced this as well.
6If you feel dizzy when looking at the left side mirror because it seems magnified, especially after switching your gaze from the right, it might be due to the mirror's curvature or your seating position. Consider adjusting either the mirror or your seat to find a more comfortable view.
7Is the GV70's all-wheel drive truly full-time, and what is the front-rear power distribution ratio? I've seen some owners say it's not full-time AWD, mentioning that some modes require manual adjustment to four-wheel drive or allow switching to two-wheel drive. I'm a bit confused. Could someone explain the situation with this AWD system and how to use it?
8Guys, today I tried flooring it in Sport+ mode and heard a rustling sound that lasted about 5 seconds before disappearing. No error codes on the dashboard, and the car drives fine. However, when I parked and shifted to P, there was a continuous electrical noise. The noise disappeared after switching to neutral and back to P. Could there be an issue with the transmission? How should I check it?
9My 207's automatic air conditioning is having issues. The air only blows towards the windshield and can't be switched to other directions. The display on the panel works, but it doesn't actually change. The AC compressor starts, but it keeps blowing hot air. The temperature adjustment panel shows the settings, but the temperature doesn't change.
10The 2008 model doesn't have automatic air conditioning or physical buttons for the AC, making it hard to adjust to a comfortable setting. Frequently using the screen to adjust can be distracting. Do you have any good solutions for this? Also, it's been raining a lot recently, causing more fogging. Turning on the defogger feels like hot air, and when you turn it off, you need to adjust the AC again. 🤔
