عبدالله محسن
عبدالله محسن
Sep 10
It seems like your 2011 Phaeton is experiencing some issues with the remote unlocking and the keyless start system. Sometimes you have to use the mechanical key to lock and unlock the car, and the keyless start doesn't work. Occasionally, after using the mechanical key to start and then turning off the engine, the remote unlocking and keyless start work fine again. What could be the problem?
سلمان مكتوم
سلمان مكتوم2021-09-13 13:18
I had a similar issue with the same car model. Replaced the auxiliary battery, and the problem was solved immediately! The technician explained that the battery was old and couldn't supply enough current.
I disassembled the Peugeot 301 key and moved the chip to a new case, with the metal key separate. Now, the remote can unlock the door, but the metal key won't start the car. Could it be the key issue that's causing the car not to start?
The second key hasn't been used for a while. Recently, I took it out and found that the remote doesn't work. I changed the battery, but it still doesn't work. Does anyone know why?
Are there any 2011 models that have been modified with keyless start? [Facepalm][Facepalm][Facepalm]
2020 Volkswagen T-Cross, registered in 2021, and in 2022 the keyless entry stopped working, so you can only use the remote to unlock the door. Does anyone know what might be the issue?
The keyless entry function on the GS 5 is not working properly. Approaching the vehicle no longer locks or unlocks it, and the function is unresponsive. The key fob's battery was just replaced. What's going on here?
It seems that the 2011 Nissan Sunny doesn't have an engine immobilizer. I can just use a mechanical key to unlock the door and drive away.
2014 Peugeot 2008 manual transmission, the remote key can't unlock the driver's door (can open with the key), while the other three doors work fine. Any advice on how to solve this issue? 🙏🙏🙏
Can the 2017 Haval H2 Automatic Elite be started with a mechanical key?
The car hasn't been driven for just two days, and the door can't be unlocked. I used the mechanical key to open the door, but there's no power at all inside. What's going on?
