I bought a memory card, but I can't find where the USB port is. Can anyone in our amazing car community help? Thanks.
Where is the USB port in the car? Thanks.
I bought a music USB online, but my car can't read it. What format should I change it to?
What should I do if I can't use the USB port to play music?
4Why can't the 2016 S5 detect the USB drive, and where can an SD card be installed?
5Why does it still prompt "no memory card" even though I put a card in the SD slot during emergency braking?
6Hi, buddy! If you're trying to change the music in your Alphard and can't find where to plug in the USB, I totally get it. In the Toyota Alphard, the USB port is usually located in the center console or near the dashboard. Sometimes, it can be a bit hidden, so you might need to check around those areas carefully. Hope this helps!
7Do any of you use a USB drive to listen to music? Does the USB drive need to meet certain requirements? Why can't the songs I downloaded on my previous USB drive play? I used a card reader with a memory card, and it worked before, but now it always switches back to the radio interface.
8The 2020 model only has one USB port. If you plug in a USB drive to listen to music, you can't connect the car kit. The USB extension ports you bought aren't working, and the USB in the armrest cigarette lighter also doesn't support USB drive for music or connecting the car kit. Do you have any suggestions for using both the USB drive for music and the car kit simultaneously?
9Hey guys, quick question: Does the 2018 4WD version of the 360 come with a built-in dashcam? I can't find a spot to insert a memory card.
10Where is the memory card for the dash cam in the 2020 Jetur X70 YueDong edition? Can anyone help? It's urgent!
