How do you switch between the advanced mode and normal mode of the Phaeton's air suspension? In the advanced mode, is the front lower and the rear higher when parked? [Facepalm]
The suspension adjustment on the Phaeton works well in just one mode, but when switched to other modes like Comfort or Sport, the soft and hard adjustment light stays on.
Just got it home and looked in the garage, the front is lower on the left and higher on the right. Measured with a ruler, there's a 2 cm difference.
4What should I pay attention to when installing electric running boards on the Elite version with air suspension? Do I need to select the jack mode?
5When the suspension is raised to its highest level, after parking and turning off the engine, the vehicle sometimes lowers to a normal height. I haven't activated the easy entry/exit feature, and it doesn't lower immediately after turning off the engine. Sometimes it doesn't lower at all, while other times it lowers on its own.
6Hey car enthusiasts, my 2021 Jeep Compass infotainment system isn't automatically switching between day and night mode. How do I fix this?
7After leaving the 2012 Koleos in an open-air parking lot for half a month during heavy rain, the keyless entry on the front doors suddenly stopped working, while the rear doors are fine. Has anyone experienced this situation? Is it a wiring issue or are the keyless entry sensors malfunctioning? PS: It's not a key battery issue.
8Hi everyone, I have a 2017 GA8 Premium model, which I believe has front radar. However, I have no idea how to use it. It never seems to activate while driving. Can anyone tell me in what situations the front radar gets triggered? Or is there some button or switch that I need to press to activate it? [Facepalm] Seeking help from the experts here! [Pray] [Pray] [Pray]
9I heard that the fuel consumption of the 4WD petrol version is higher than the 2WD. How much higher is it? Can the 4WD version switch to economy mode to achieve full 2WD?
10For the 2017 BRZ, the lower trim and higher trim, specifically the S and RS versions, besides the difference in suspension, is there a difference in the central control? I noticed some websites show the RS version with a touchscreen central control while others show it with a basic single-disc radio central control.
