عمر صلاح
2022-11-15 20:24
Hello everyone, can anyone advise on which brand and model of transmission oil is suitable for a 2013 Phaeton 3.0, non-turbo version? How can I ensure I'm buying genuine products? Also, is there any suitable option from Mobil for this? Thanks.
عمر صلاح
عمر صلاح2022-11-16 22:10
Do any of you have a WeChat group?
When comparing the comfort of the McLaren 720S and the Porsche 911 Turbo S for long-distance driving, it's important to consider a few factors. The 911 Turbo S is generally known for its more refined and comfortable ride, making it a better option for long trips. It often offers better build quality and reliability, which can be reassuring. On the other hand, the McLaren 720S is admired for its striking design and performance. However, it might not match the 911 Turbo S in terms of comfort and ride quality for extended journeys. Ultimately, if exterior design is a priority for you, the 720S is a great choice, but for long-distance comfort and reliability, the 911 Turbo S might be the better option.
Does our car's infotainment system use its own data or does it need a mobile hotspot? I see there's an online upgrade option for navigation. Can the system connect to the internet by itself?
Is the 2012 3.0 FSI Phaeton equipped with a ZF or Aisin transmission? I've been looking into changing the transmission oil and asked the ZF flagship store, and they recommended I use oil for an 8-speed transmission. Shouldn't it be for a 6-speed? Can someone knowledgeable help me out? Thanks!
For a 2011 Volkswagen Phaeton with 130,000 kilometers, experiencing issues with the key frequently failing to unlock the doors or the car not detecting the key inside, along with a loud engine noise, here's what you can do: 1. **Key Issues:** - **Battery Check:** Start by checking and replacing the battery in your key fob, as a weak battery can cause these problems. - **Signal Interference:** Ensure there is no electronic interference around you when using the key. Sometimes other devices can disrupt the signal. - **Reprogramming:** If the issue persists, consider having the key reprogrammed by a professional. 2. **Engine Noise:** - **Oil Level and Quality:** Check the engine oil level and quality. Low or dirty oil can increase engine noise. - **Regular Maintenance:** Ensure regular maintenance is performed, including oil changes and tune-ups, to keep the engine running smoothly. - **Inspect Components:** Have a mechanic inspect the engine components like the timing belt, exhaust system, and other parts that might contribute to the noise. Regular maintenance and addressing minor issues promptly can help maintain the car's performance and longevity.
Can anyone advise if the 2005 T6 2.9 twin-turbo is worth buying?
You can purchase welcome lights for your MDX from online retailers such as Amazon or eBay. Additionally, you may find them at automotive parts stores or websites that specialize in car accessories. Make sure to check the product specifications to ensure compatibility with your vehicle model.
Is the Scirocco really that problematic? Do the engines need frequent repairs? And do things like spark plugs often fail too? I'm considering getting a 2.0 or an R model. Can any car experts advise on which year model is more suitable?
