سعود يعقوبي
سعود يعقوبي
Nov 30
To replace the cigarette lighter fuse, follow these steps: 1. **Locate the Fuse Box**: Usually found under the dashboard or in the engine compartment. 2. **Identify the Fuse**: Check the diagram on the fuse box cover to find the cigarette lighter fuse. 3. **Remove the Fuse**: Use a fuse puller or a pair of pliers to carefully pull out the burnt fuse. 4. **Replace the Fuse**: Insert a new fuse of the same amperage rating in the same slot. 5. **Test**: Turn on the ignition and check if the cigarette lighter works. If you're unsure, consult your vehicle's manual or contact a professional.
سعود جل
سعود جل2024-11-30 23:55
The vehicle's user manual should have specific fuse amperage details, so you can replace them accordingly.
Peugeot 408
Peugeot 408TBDGasoline
